you're using cyanogenmod, I'm assuming. try long pressing the notification, then hit app info. then disable the notification from there by unchecking the little box. I can't test it right now since I'm running simplicity
I'm also running simplicity. Its the "no simcard" icon. Can't long press it.
you mean the one on the home screen? oh yeah...i don't think you can remove that. I just learned to deal with it. is your phone in airplane mode? it saves battery and I think it removes the notification...
The one next to the WiFi icon.Won't airplane mode turn off WiFi and sync?
You can always manually turn it on after enabling Airplane Mode.
