D-U-R-X
turbo drinker
This is a work in progress... Please continue to post support questions in the forum, but feel free to add to the FAQ's and we will update this post (to avoid information being lost later in the thread).
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Optimus M Plus Tips & Tricks?
4. What are the known problems with the Optimus M Plus?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I check for updates for my LG?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Here are a couple of things that you could consider - adjust the screen brightness, do not use live wallpapers, switch off networks when not in use (WIFI, Bluetooth, GPS), adjust update intervals for widgets (do you really need twitter/facebook notifications every half hour?). You could also consider downloading a battery monitoring app such as JuiceDefender.
Q: Are there any Optimus M Plus Tips & Tricks?
Q: What are some of the problems people have with their Optimus M Plus?
Q: How can I check for updates for my LG?
A: Here is a thread detailing that
