Help Optimus M users having 3G PRL 3020-3025
Chckycrk
So I believe the problem is that some Optimus M devices have Rev.A qualcomm chips and some just have Rev.0
Not exactly sure why but that would be a very possible explanation as to why PRLs 3020-3025 have only granted a 3G signal to some users (other than geographical location)
would anyone else know of this?
And how would someone go about checking which chip they have in their phone? I just started seeing flashes of 3g in the suburbs of detroit (posted in that section a few minutes ago) and curious about finding which rev I have. I've seen some rev numbers in setCPU but just want to be sure I'm looking in the right place. Thanks.
Get the LTE On/Off app from the market. Put your setting to evdo only. then look in your phone setting/ about phone/ status, then scroll down to Mobile Network Type. It will say your rev. type there.
I currently have 3023, i updated using lgpnst. my pc is no longer available to me, can i update to 3025 without pc. Im rooted running cm7 playfulgods current build if it matters any. thanks in advance.
No, unfortunately... Find a family member or friend that can let you borrow the PC for about 10 - 15 mins including download time for qpst, if the internet is good.
Thanks for the time to reply. Also, am i correct in thinking metro pcs store will not update to 3025 for me. Prolly not, but cant hurt to ask.
