Help Orange UK MMS Problems
ejh
Hi
Ive been having problems with MMS settings on my nexus one. Ive checked my APN settings and they are all as suggested by Orange (albeit for the HTC Desire, but they should be exactly the same right?), take from here:
Orange Setup
Orange Setup
Anyway after I double checked all the APN settings and quickly retried to recieve the MMS one was downloaded, the other was not. Since then I still have no luck downloading the other MMS. Ive called Orange and they say it isnt a problem at thier end (Ive even been able to send other MMSs on other phones but this message isnt on the sim.)
Is there anything that could be causing my phone to download MMS messages one moment but not the next (I do have signal / data connectivity)
The message i get is "Download of message (No Subject) from RecipientName was not succesfull"
Thanks for any help you can give.
