Order and Chaos
zizzlfied
It is lagging on my evo but it is compatible to the evo shift. IT runs crappy assuming that it runs great on the shift. Why? Anytips for it to run better? I can run Modern Combat and dungeon hunter HD
Believe it or not the Shift has a better gpu than the original EVO 4g. EVO 4g uses Andreno 200 and Shift uses Andreno 205 which was quite the upgrade. This is why you will see more games available on Shift then EVO 4g
