Original Home screen clock widget?
TobesEtc
I use ADW Launcher on my S3. My friend just bought an S3 and has hardly changed the layout at all. When we were comparing the two I realised that I cannot find the original clock widget that comes on the home screen. See attached.
What is it called...or is there a reason why I've no longer got it?
AFAIK you can only use the clock widget if you are using Touchwiz as your main launcher. It's still on your phone but won't show up in the widgets if you are using ADW
