I just got the update and I think I may have forced it going threw this thread I saw that the file was hosted and then I downloaded it then used anycut from the market to open the device management and clicked start dm then I noticed the red and blue arrows minutes later I got the notification and boom update
plz someone try it and tell me if this works
Partitions with file systems should be accessed via STL devices with no offset - edited table.
...Code:[COLOR=Blue][B]Device Partition Image Offset Size (KiB)[/B][/COLOR] bml1 MIBIM arm9boot 2048 bml2 OEMSBL1 arm9boot @0x200000 512 bml3 OEMSBL2 [I]{blank}[/I] 512 bml4 APPSBL arm11boot 1024 bml5 AMSS amss 23040 bml6 RECOVER recovery 6144 bml7 EFS2 [I]{radioFS}[/I] 0xA80000 23040 bml8 APPS kernel 6144 [COLOR=Orange]stl9[/COLOR] EFS2APPS system [COLOR=Orange][s]0xA80000[/s][/COLOR] 226304 bml10 FOTA [I]{blank}[/I] 8192 bml11 RFBACKUP [I]{blank}[/I] 512 [COLOR=Orange]stl12[/COLOR] CACHE cache [COLOR=Orange][s]0xA80000[/s][/COLOR] 40960 bml13 PARAM [I]{unknown}[/I] 1024 [COLOR=Orange]stl14[/COLOR] USERDATA userdata 173568
Update: Simply hexediting the flash file system header out so that the remaining image matches the contents of the original ODIN images does not seem to work.
The problem is that dumping the BML devices with files systems on them (vs RAW) produces an image that is too large. In the originals, all the files were allocated near the beginning of the ROM, and the rest was zeroed (in NAND flash this means 0xFF). After the update I noticed that files were allocated at the end as well. This means one cannot simply remove the extra zeroed space to make it fit for ODIN.
The STL devices work at a higher level, translating addresses in flash so they can work with normal file systems. Using an STL image instead of the edited BML image may work.
The downside of using STL devices for file system dumps is that they are only enabled on specific partitions. The good thing is these other partitions do not really concern us unless we want to edit the radio code (lets leave this alone).
Unfortunately the error in trying to flash the BML image forced me to ODIN back to the UVIJ6 firmware. Once I receive the update again I will test the new ROM dump and release a no-root-needed ROM update via ODIN if it works.
@Nu11u5 - Let me know if you can get the Update to reinitiate. I ODIN'ed back to stock expecting that I would be able to re-download the Update and that has not been the case. No one at TMO has been able to help. Consequently they are shipping me a "new" phone that will "hopefully" have the update on it.
If you can point me to some good directions on I'd love to know how to do a dump. I have googled it but clearly I am not catching the right phrase since all the results are related to posts about finding a ROM dump, but not how to perform one.
Final question, how do you restore from a ROM dump? I am quite experienced with ODIN at this point, but this seems something different.
