Root OTA Update then no connection to pc HELP!
khanet
After receiving the update last night, i defrosted all my apps and did a backup before i installed update. Install complete and was ok. I went back in to root my phone and it will not connect to my pc. It no longer gives me a choice on what mode i want my phone to be in. Does anyone know how to change it? Thanks.
I did not delete anything, just froze some apps with titanium, my phone works perfect and runs even better after the OTA but i can't get it connected to my pc to get root again.
This might sound sarcastic, but I'm serious... Have you tried turning it off, then back on again, and then connecting?
yeah, i understand where you are coming from, people always overlook the simple things, but yes i did do that many times. I just tried to do a nandroid restore and i think i bricked my phone from doing that. now i can't get it to boot at all. i also put that nexus prime bootloader on it so i dont' know if thats holding up the process or what. I need lots of help.
I'd suggest trying to boot into Android recovery then applying the leak and hope that gets you to stock 5.6.890.
Disclaimer...I'm newer to this stuff, so don't run off and do this until someone more experienced chimes in/agrees/whatever.
I ended up applying the leaked sbf to my phone which allowed me to boot to it. the update applied and set the phone for factory reset. Took it to verizon told them my phone is whacked out from that update and she looked over it and said "Yes, these are all the problems we experiencing with the update on some phones." All that time i thought it was the Freezing apps and being rooted that messed everything up but it was just the update. They overnighted me the phone and I should have it in a couple hours.
Interesting... Why is no one having these issues with the leak, but, as per Verizon's word, they are with the OTA?
these things happen being a tech for vzw i seen alot of bs and it was like wtf, but i mean thats technology at its best lmao i aint smart like some of these dudes on here but alot of people do dumbshit an blame the phone when its user errror....on another note i just did the ota before work this morning an it didnt brick, because i had removed amazon , skype , nfl mobile and i had knots in my stomach doing this, but it worked what a relief gonna try and root now.
as i scroll through the new ota droid 3 , it added back amazon kindle and nfl mobile but no skype, i guess it doesnt care for it.
now i am experiencing the same problem, not connecting to pc it sayes it chargin when the screen is looked though restarted abunch of times, took out the battery, i really dnt wanna have to go to vzw after work, traffic blah! im out laters everyone hope someone finds a fix
Update:
Got a new phone overnighted to me from verizon received the update for it this morning and it did the same thing not connecting to pc. took a laptop and my cord to verizon. they looked at it couldnt' figure it out. we decided to try another cord and it worked. was a blackberry cord. so she went and got a brand new droid 3 out of box and that cord wouldn't work. I asked her to get a bionic cord and she did.......and it worked like a charm. for some reason my original cord didn't work after the update. but everything works now and i have no idea why it doesn't accept the original cord.
I got an update for the Moto PC drivers yesterday, one day before the OTA was available for my area. Just a coincidence?
My MotoHelper is now 02.00.53 with Motorola USB Driver 05.02.00
And after the OTA update on my wife's phone (never rooted) the PC connection is working normally.
I recall that I had an issue with the D3 connecting to the PC originally until I installed the then current drivers.
i did that , reseted my phone and use the chargin cord that came with the phone an its back to working..
I'm so glad I found this thread. I was having the same problem - couldn't connect my D3 to my PC anymore after the OTA update. I have about a dozen micro USB cables and the only one that allows me to connect the phone to PC is the one that came with my phone!
Good news is the phone will connect after OTA and Pete's 1 click root method worked just fine.
My Droid 3 is running great rooted with 5.6.890!
