Help OTG Cable & viewing AVI
jhill0224
1.) OTG: Traveling to India on a missions trip so to travel lighter I'm taking only my xoom. I purchased the OTG cable to hook up to a memory card reader to transfer images from my cameras memory card to my xoom. Hooked it up and nothing. Hooking a usb flash drive up and the light would flash for a second then quit... What am I doing wrong?
2.) What is teh best video player to play AVI on the xoom. DL'd a bunch of movies for the flights.
hi,
you need to root your device in order to accomplish what you want to do in question #1. there is a rooting section here and if you search OTG you will find answers.
as for #2, there are several and are discussed in this forum.
i personally use:
dice player
mobo player
in that order.
