OTG SOLVED
I have a video to go with it.
https://www.youtube.com/watch?v=xVpCs_SAEUA
Thank you OverByte and Leslie Ann for replying to my support question.
I flashed this rom here: from Anthrax website
Anthrax Development - Home of the first custom shooter ICS kernel
Install stickmount.apk along with formating my usb to fat32.
*Mounted successfully.
*Keyboard works successfully
*USB wireless mouse seems to not work? but will try with a wired as I do have one.
*I am also wondering if OTG works with webcams? As I do have 3 different brands of webcams.
-----Microsoft LifeCam Studio 1080p, a Logitech 320p cam, and lastly a Playstation 3 Webcam.-----
I inserted the webcam to usb hub port one by one but skype doesn't support my cams.
Maybe there is another app or something like a kernel I suppose. Sorry if this is over doing the phone. I'm just thinking what works and what doesn't work in the usb devices.
OLD UPDATED POST: 11/29/12 IGNORE THIS POST PART. Read above how I solved it.
Now that I am S-OFF and can downgrade/UPGRADE HBOOT.
I downgraded to 1.04 but can upgrade it as well.
I have been looking at HTC EVO 3D roms on XDA developer site such as
Another thing is that would I need to flash a OTA? or is that included with the rom.
sorry I'm a newbie. I followed Leslie Ann's guide but wasn't sure if it would have radio problems cause it's on a virgin mobile even though it's from Sprint?
http://androidforums.com/evo-v-4g-a...ng-turning-your-phone-into-evo-3d-thread.html
OLD POST: I found more info. Read above text. ^
I am using Leslie Ann's Harmonia rom 3.17 and flashed Mobster Power Kernel. I'm thinking to myself I messed up by flashing Mobster. I believe I need to flash/install anthrax. I'm using TWRP 2.2...
Would I need to find a OTG supported kernel and flash that with Harmonia?
I have 2 OTG with Female ends like in the video and they do charge my phone but when I use stick mount it can't detect my 2GB usb drive?
Samsung Galaxy S2 - How to use Pen Drive, USB Mouse, OTG Cable, USB Jig, Call Recorder - YouTube
Using htc v 4g with 32 GB.
Skype me to help? just post here and i'll add you. Thank you have a nice one.
All i'm trying to do is get my usb keyboard to work and mouse etc...
Code:
http://forum.xda-developers.com/showpost.php?p=30014044&postcount=7
This one seems to be supported so I'll test it.
http://anthrax-kernels.us/forum/showthread.php?t=200
I found this one amoung the searching on xda.
http://forum.xda-developers.com/showthread.php?t=1673430&highlight=htc+evo+otg
Code:
http://androidforums.com/evo-v-4g-all-things-root/622841-usb-otg-working.html
