Help ott tv box
  • Start date Start date
A
Android Question
Guest
Hi i'm trying to upgrade Kodi on my new ott tv box.but I get this window saying for security,your phone is set to block installation of apps obtained from unknown sources. Please help thanks.
You can change this through settings> security and allow installation from unknown sources or you could download the latest update (Jarvis) without doing this, from Playstore
Hi I've just got a new box delivered from Amazon .. I've set it up and comes up with the same as above thread .. Also when I go into look for movies there is nothing showing .. As if there is nothing there at all ..
I'm not so great on techn and any help appreciated
Thankyou
