Accessories otterbox case not fitting properly on eris
Adam63impala
does anyone else have the otterbox impact case ? wondering if mine is the only one that isn't fitting properly. the top of it is now sitting above the ear piece and sensor hole.
That's odd it doesn't fit. Otter box is great. As I do not have the Impact case, I do
however have the Commuter Case and I absolutely love it, I won't take my phone
anywhere without it.
How many drops has it survived in that case? I am thinking of purchasing that case when I order the eris.
i have an otterbox impact case and its true about not fitting properly, the form is good and everything but its loose. it was getting annoying because it would cover up the sensor and the led. what i did was take some 3m padded tape and put it on either side where the mini usb port is, now it fits snug and doesnt cover the sensor/led.
I also have the commuter case and love it. It has saved my phone many times. I do have a habit of dropping it and knocking it off counters and my desk at work. It also comes with a great screen protector that goes on smooth and is not noticeable, highly recommended. I bought the case from newegg at about one third off the price of the otterbox site.
