Otterbox Commuter REVIEW
Nice review. Glad that you pointed out how it fits all the way around the sides and top of the phone. The Seidio Active polycarbonate shell doesn't go all the way around the phone and is thus much easier to separate the silicone from the phone around the sides.
Does this case work with the extended battery?
It works with the extended battery but the shell won't be snug. When I need to use it, I find myself checking to see that it's not popping off.
Thanks. WIth the SEidio active it also fits but the fit is off just a bit. It works but I sure would like to find a hybrid case like these that actually fit the phone properly with the extended battery.
