Help OUT THE BOX ACTIVATED PHONE WITH 4G LTE DATA PROBLEMS
This phone is a few days old and it's 4G LTE Data been wishy washy.
It times out multiple times causing me to put it in airplane mode too many times throughout the day.
Help? I called support and did everything.
Anybody experiencing this?
Try using 4G. Not 4g lte but just 4g. 4G is always way faster as the 4G towers are never congested and most people have moved on to 4G LTE
Thanks I will try that.
Also to use lte with stability use airplane mode, reboot, put in *#*#4636*#*# in the dialer. There will be a drop down menu that should say "LTE/GSM/WCDMA. Tap that and scroll down until you see lte only. Then select lte only,let it reconnect then switch back to the LTE/GSM/WCDMA option. If it connects to 4g and not lte its fine it will eventually connect to lte. If it doesnt within 2 minutes toggle data on and off once or twice. This almost always works for me.
