Help Outgoing SMTP Settings
I did a search but didn't exactly find what I need, so here goes.
I have my work email set up on my GS3. Those outgoing SMTP settings work fine when I am on a WIFI connection, but will not send when I have cell only coverage.
Before anyone suggests, I do not want to us Gmail for this particular email address.
Does anyone recommend the correct outgoing SMTP server settings when trying to send over cell? I'm on ATT. Thanks!
Hmm, it should work the same via either one.
Does your company have an IT department? Since this is going to depend heavily on what they use for settings I would try to contact them.
