When you update something, you update it from one version to another version.
If the update broke the app, uninstall it and install your backup of the previous version.
Then contact the author and give a detailed description of the problem so they can fix it.
I have just re-downloaded latest Outlook from Play store and it seems to be working here. I would suggest clear cache. If that doesn't work clear data. After clearing data though you will need to log back in and it will need to refresh your mail etc.
There are many apk backup programs, including most of the better file managers.
If you have not been backing up your downloaded apps you should start now.
