Google 'MyPhoneExplorer'. Client on PC and app. on the phone.
Dave
Doesn't do Contacts? Is that right?
Dave
I've been using MyPhoneExplorer for a while and it does the buis for me.
Re overwriting. There are options to 'force' to/from outlook/phone and you get a 'confirmation' pop-up which shows the difference between entry details. This allows you to force either way or abort.
MPE defintelty does NOT delete unsync'd fields. It simply leaves them on the PC.
