It sounds like you are working on a development project. You might find better answers in Developer 101 - Android Forums. Someone there should be able to answer your question.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
I hope you'll find this place helpful. Thanks for joining our community. <( ̄︶ ̄> []~( ̄▽ ̄~* ( ̄﹏ ̄ ( ̄ˇ ̄
