Root Overclocking Guide[AreaRom2.3/3.0/3.1/3.2]
AMOCO
The Computer Guy
Ok,A few of you want to know how I'm able to get such high benchmark scores.
Let me mention a few things you will need to get high OC's and benchmark scores
1)Samsung Galaxy Precedent Smartphone.
2)32gb. Class 10 Micro SD Card.(Any Class 10 SD Card for better benchmark scores)
3)
A:AreaRom2.3;Link;http://androidarea51.com/arearom-galaxy-precedent-releases/idiots-guide-installing-(rom)(stable)arearom-v2-3/
B:AreaRom3.0;Link;http://androidarea51.com/arearom-galaxy-precedent-releases/idiots-guide-installing-(rom)(stable)arearom-v3-0/
C:AreaRom3.1;Link;http://androidarea51.com/arearom-galaxy-precedent-releases/(rom)-arearom-3-1/
D:AreaRom3.2;Link;http://androidarea51.com/arearom-galaxy-precedent-releases/idiots-guide-installing-(rom)(stable)arearom-v3-2/
4)Kernel{Genocide_187} 2.6.35.14 OC+I/O+Gov_beta_1,Link:http://androidforums.com/precedent-...nocide_187-2-6-35-14-oc-i-o-gov_beta_1-a.html
Which will work on AR2.3/3.0 & May work on AR3.1(I didn't test it)(Kernel Built By The~Skater~187)
5)Or this kernel{AK51 946mhz OC Kernel with /SD-EXT Modification},Link:http://androidarea51.com/releases/samsprec/arearom/cpucontrol.zip
Now this kernel will only work on AreaRom3.1(Kernel Built By DroidHost)
6)No-Frills CPU Control,Link:https://play.google.com/store/apps/...DEsIml0LnNpbmVvLmFuZHJvaWQubm9GcmlsbHNDUFUiXQ..
7)SD Speed Increase,Link:https://play.google.com/store/apps/...t=W251bGwsMSwyLDEsImNvbS5zZGluY3JlYXNlLml0Il0.
8)AnTuTu Benchmark,Link:https://play.google.com/store/apps/...chMark&feature=nav_result#?t=W251bGwsMSwyLDNd
9)Memory Cleaner,Link:https://play.google.com/store/apps/...S5nYW5uaWN1cy5hbmRyb2lkLm1lbW9yeWNsZWFuZXIiXQ..
If your on AreaRom3.1(As it doesn't have the Task Manager to clear memory)
Now we can get started benchmarking.
Remember when benchmarking,You only want AnTuTu,SD Speed,& No-Frills CPU running while testing.
1)I do a quick clean up using Advanced Task Killer,History Eraser,& Memory Cleaner/Task Manager.
2)Then I start up No-Frills CPU Control & set to desired CPU Speed.
3)Then I open SD Speed Increase & set to desired SD Speed.(I find 3072kb. is a good setting with a Class 10 SD Card)
4)And then I start the AnTuTu Benchmark Test.
And there you go,You need to work with the setting in No-Frills CPU Control to get the best Benchmark Scores.
Just ask if you have any questions and enjoy.
