Root Overclocking help needed
oam
Ok, so ive rooted my phone and installed the milestone overclock app. I've read the sticky thread about overclocking but im quite confused. I know what the cpu clock speed is and i can see that on the overclock program, but in the settings, it has a list of speeds which i can customize.
Custom rate (KHz) 1200000
Custom vsel 80
what does that 1200000 khz translate to in regards to MHz? and how high is safe?
What is the safe range for the vsel?
Custom vsel 80
I believe that is 1.2GHz. I could be translating it wrong but thats what my phone is oc'ed too(1.2GHz) and I have no problems with my phone at all. It's really fast and things run smoothly. My battery will last me a day and a half so there is no issue with battery draining to fast.
Custom vsel 80
1,000=Mega or 1Mhz
1,000,000=Giga or 1000Mhz or 1.0Ghz.
Make sense? 1200000 would be 1.2 Ghz. I have mine custom set at 700000=700 Mhz
If I'm wrong, someone will correct me I'm sure.
1,000=Mega or 1Mhz
Yes I believe your correct as it makes sense to me as well. That's just like 1000mb = 1gb.
