Overheat, lag, not showing notification
kook77
Hello !
I upgrade from note 2 to note 3 also used the tab and tab 7.7 and I love and hate Samsung for some reasons!
Overheat: For some of you may think 38C is normal but this temperature definitely is too hot for me and I scare of it will explode suddenly, I was using wifi, wechat, facebook, instagram and I haven't root the phone, (Nova launcher), I am not a gamer, 32G SD card I used only 3 gb for music. The adaptor is a little warm as well while charging I hope that's normal because the note 2 was in a correct temperature in the last 1 year, however I found the cable turned to black color like overcooked, now I am looking if any of you have any idea to cool down the phone because I don't think this is healthy for the screen.
Lag: This problem mainly comes from playstore, first of all this always showing 'No network' while I was on wifi, so it will be fine when I search again, this look really stupid after I search something it shows 'No network' first...and second, while I am able to find an app, I tab it, it would stuck on that screen for some seconds and then forced close. Anyone know why??? Also some other apps I was received forced close from time to time but I don't know if that's the program's problem or note 3. But it is way more easy to have lag on playstore. (No problem from note 2 )
Notification: I installed facebook messenger and wechat, I got a problem that notification is coming only from time to time, sometimes it is not showing anything until I opened the app to check if anyone sent me message. Because of this my friends got angry of me :(
I wondering if above problems are normal or just me is like that, otherwise I will send it back to Samsung to check, I already did a factory reset and problems on-going.
I never had any heating problems but tonight I did notice that it got a bit on the warmer side and the weather here is cool. I also do not charge battery with the battery in the phi as I bought the external battery charger and spare battery so I just swap in a new freshly charged battery when my battery runs out.
