Hello everyone, my Infuse gets very hot at times especially when charging. It almost gets so hot that I cannot hold it for longer than 10 seconds and it shuts off. What can be the problem?
Yes, using CPU-intensive apps while charging will tend to overheat the device. If you are willing to root your phone, you can install SetCPU with a profile to reduce CPU frequency when it reaches a predetermined temperature. Problem solved.
