Overriding security lock temporarily
GregwGA
My wife and I sleep in separate bedrooms (we are old folks) because of my work schedule. I would like to be able to, before I go to bed, override the security settings (until I get up in the morning) on my phone so that in the event of an emergency and I need to call her (or 911), I don't have to unlock my phone before calling for help.
An app would be OK to do this
Smart Lock could work.
Google Smart Lock works with your devices using Android and/or Google to remember your passwords (including Android smartphones, Chrome and apps, and Chromebooks)
It has a number of different functionalities, including allowing you to set security bypasses in certain places or when you connect to certain devices, allowing you to skip your screen lock type giving you quicker access to your device.
http://www.samsung.com/uk/support/skp/faq/1105600
