Help P500 wont turn on, hard reset not working
hi i have my P500 and was trying to update to gingerbread, unfortunately got an error. then when i was trying to turn on the phone, i cant. it wont event do a hard reset. T_T please help.
heres the error log i got from updating:
[R&D Test Tools Log File]
22:35:45 : Launching SW update
22:35:45 : Unpacking KDZ
22:35:57 : KDZ file extraced
22:36:10 : Files were extracted.
22:36:10 : LGMobileDL Load.
22:36:10 : Port = -1
22:36:10 : Connecting to phone
22:36:23 : Check Phone mode = 1
22:36:40 : Phone type check.......
22:36:40 : LGMobileDL.DLL Loading....
22:36:40 : _SetAuthMark Ok : wAuthMark(8264)
22:36:40 : _DetachDLL Call
22:36:40 : _DetachDLL Call End
22:36:40 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\DZ_GT540AT-00-V20e-BAL-XXX-MAR-22-2011.dz
22:36:40 : Param : moduleDir =
22:36:40 : Param : waitTime = 1
22:36:40 : Param : UsbHighSpeed = 1
22:36:40 : Param : PhoneMode = 1
22:36:40 : Param : BinVersion = V20E_00
22:36:40 : Param : AuthMark = 8264
22:36:40 : Call fn_StartUpgrade
22:36:55 : 3GQCT : wParam = 4, lParam = 0
22:36:55 : Step Complete : DLOAD Change
22:37:40 : 3GQCT : wParam = 3, lParam = 0
22:37:40 : Step Complete : C Drive Erase
22:38:24 : 3GQCT : wParam = 100, lParam = 6
22:38:24 : Step : Upgrade Error error code = 6
22:38:24 : ResetStartInfo() Call
22:38:24 : _DetachDLL Call
22:38:24 : _DetachDLL Call End
22:38:24 : FreeLibrary Call
22:38:24 : FreeLibrary Call End
22:38:24 : ResetStartInfo() Call End
22:38:25 : ===FINISHED===
Guyz i donot use kdz for upgrade coz i bricked my phone once with it.
Use LGMDP
For using lgmdp you need to extract all files from kdz.
1. First you download any kdz file (google it)
2. Follow : [HOWTO] Cook your custom rom for LG P500 - xda-developers
Follow above thread till step 2 i.e untill you get stockrom folder. Stockrom folder has all files of kdz extracted.
3. Now download LGMDP : http://www.mediafire.com/?ov799yg7vbnce9j
AND DISABLE ALL LG MODEMS in (device manager -> modems)
4. Start LGMDP
5. connect phone to pc (if not booting into rom connect in emergency mode)
5. press "Select Port" phone should automatically be detected.
Then press "connect".
6. A window will pop up for image folder selection close it.
7. Back up nv for safety (tools->nv backup) {you can use this step if phone is booting into rom, if you cannot boot into rom ignore this step}
8. Now press "image select"
9. browse "image folder" to the stockrom folder which you created.
10. press start or download
DONOT DISCONNECT MOBILE UNTILL IT SHOWS DOWNLOAD COMPLETE AT BOTTOM.
before using lgmdp be sure to take nv2 back up if it gets lost then no gsm....and dont use lgmdp from emergency mode without nv2 backup
