k0nane
Android Expert
I found the source of the root headaches while digging through smali - in server.jar > com > android > server > PackageManagerService.smali, a conditional in the scanPackageLI method has the following:
Yep - that's exactly what it looks like. We were indeed right the first time - package installation of Superuser (and as you can see, others) is being blocked.
Unfortunately for them, I removed Carrier IQ on Sprint. This is a cakewalk. It's possible to remove this conditional altogether, but more hassle than it's worth. Instead, I replaced the package names with some pithy messages. After a little cleanup, and a reroot with stock Superuser and its standard su binary...
Here's a little message for MetroPCS.
Code:
move-object/from16 v0, p1
iget-object v0, v0, Landroid/content/pm/PackageParser$Package;->packageName:Ljava/lang/String;
move-object v5, v0
const-string v6, "android.tether"
invoke-virtual {v5, v6}, Ljava/lang/String;->equals(Ljava/lang/Object;)Z
move-result v5
if-nez v5, :cond_184
move-object v5, v0
const-string v6, "com.noshufou.android.su"
move-result v5
move-object v5, v0
const-string v6, "com.pdanet"
move-result v5
if-eqz v5, :cond_190
