I just bought an used Galaxy Gio phone. The problem is that packet data connection does not work.
As it had Android 2.2 installed, I right away upgraded it to Android 2.3.4 via Kies. I did not try using internet via packet data on the older Android, so I can't say whether the upgrade is to blame.
Otherwise everything is just fine - I can talk over 2G and 3G, I can use wifi and surf the internet perfectly. But using internet via packet data just does not work. When an application tries connecting to internet, I see the up-arrow blinking, but down-arrow is idle (looks like only downloading has problems.. or maybe data requests are routed falsely or smth).
What I've tried so far:
So what do you think? What could be the problem?
I guess the hardware should be fine, otherwise there would be problems with talking too, no?
- tried packet data over both 2G and 3G
- turned on/off roaming - no effect
- tried another SIM-card which has packet connection working on another Android perfectly
