alejandrorg
Hi all!
I've a problem with the blueetooth (BT) of my Galaxy S2 with ICS. The thing is that the last days I had several problems with my ROM (loss of signal, 3G speed was very low, etc..). After try several ROMS I've found one which seems that works properly.
When I was trying these ROMS, I found that the original had the same problem with the BT that I've right now. In the middle, there was one ROM which works ok with the BT.
My problem:
When I pair my mobile with my car hands free, it gets freeze. The hands free said "Ok, the mobile has been sucessfully paired", however, in the mobile screen I saw the messange "pairing" but never finish.
After reboot the BT, mobile and car, I saw that finally the mobile seems to be paired, but the reality shows me that when I try to make a call, the hands free is not working, and for hence, the phone is not really paired.
I've tried to "unpair" the device from my mobile phone. I go to BT settings and press "unpair" once I selected the device, but nothing happens.
Anyone knows what is happening and a solution (something which doesn't imply to install a new ROM if it is possible).
Best,
Alejandro
My problem:
Best,
Alejandro
