Pairing bluetooth devices
I have a bluetooth keyboard from logitech designed specifically for android devices. I can pair the device but when I come back a few hours later and turn on both the device and keyboard I see that the device says connected but I cannot type anything. The only way I have got the keyboard to work again is by unpairing and pairing again. Has anyone experienced this or found a way to fix the issue?
Another bluetooth device I am having trouble with is my mouse. I have a microsoft presenter 8000 mouse. When pairing with the tablet I am prompted to enter a pin, problem is the device doesn't have a pin. I tried all of the standards but no luck. I am able to pair the mouse with my htc flyer android tablet running honeycomb as well. And ideas?
When the keyboard and tab disconnect, have you tried just turning off bluetooth on the tab and power cycling the keyboard instead of pairing them again?
Once a device is paired, it is just a matter of turning bluetooth on on both devices and they should get connected automatically.
No idea about the mouse, sorry.
Yeah, you would think so. I just did a quick test on my htc flyer, I turned on the device and the keyboard and they worked! Now I have to go home to try the same test with my galaxy, but last time I tried on my galaxy it didn't work. I hope both work and it was just a one time glitch...
Thanks.
