Pandora App Problem.
My problem isn't a big one, just an odd one.
Whenever I "minimize" pandora to the background it shows up in the status bar and the notification panel, as it should. BUT in the notification panel, the text is black against the black panel, so you can't see what song is playing unless you select the pandora app. Is that Normal?
^^ How the app looks in the notification panel.
^^ you have to "hold" the app in the notification panel to actually see whats playing.
  • you have to hold the app in the notification panel to actually see whats playing.jpg
It would seem that you need to change the background color in the notification bar. I have an Atrix 4G and my background for running apps is white with black lettering.
How would I do that? I've been through my phone several times and I have never been able to find that option, even in the accessibility settings.
