My Pandora and Bluetooth in my car work great with one exception. When I disconnect from the Bluetooth (ie. turn off the car) my Pandora keeps on playing through the speaker on the phone. I would like Pandora to behave like it does when you disconnect a wired headset and pause. I use Dogcatcher and it pauses on a Bluetooth disconnect.
Does your Pandora behave the same way?
Is there any workaround for this problem?
I contacted Pandora support about the issue but I am not even sure they understood what I was writing about.
Thanks!
Thanks!
