Help Pandora on Xoom? (issues on Wifi model 3/28/11) now FIXED 5-14-2011
chisam14
Anybody had any luck making this work? I've installed 3 times and it just Force Closes. Maybe it's not ready for Honeycomb
I've had some apps not work if I had the widget on a screen and the widget didn't work. Do the people it's not working for have the widget? Or maybe the people who it is working for have spareparts installed or something? I haven't tried it but I can when I get home.
No widget here and it works like a charm. I do have spare parts.
I had the widget, but removed it last night after the first FC. Still no luck.
Tried reinstalling it. No luck.
Tried installing Spare Parts and reboooting. No luck.
Tried reinstalling again. No luck.
Honestly, I know nothing about Spare Parts, but I did make sure the "Compatibility Mode" box was checked. Can anyone help?
Something I heard about spareparts, you need to uncheck "compatibility mode" then check it and reboot or something like that. Or uncheck, reboot or close then check? I read that somewhere on here last month.
That's fascinating. That's going to affect a lot of people as I'm quite sure a TON of people were waiting for the wifi only Xoom before jumping. UGH. I hope this gets fixed for you guys and gals soon.
Good work. The Nook Color .apk found on the second page of that thread works fine. No widget or landscape mode, but music plays and that's good enough for me.
Ugggggh, this sucks. I just got my wifi only Xoom today. Didn't realize pandora wouldn't work. Definitely wouldn't have stopped me from getting it, but sometimes these little kinks get frustrating.
Pandora is aware of it and says that they will be releasing a fix soon. And no, I don't know what 'soon' means.
