Pandora sucks on Android
kernels
I have a Droid 2 and an iPhone 3, Pandora never seems to run good on my Droid yet on my iPhone Pandora starts right up, rarely has gaps or suddenly turns off. I'm pretty sure that its the Android OS cause I've also had the same experience with my old Samsung phone which was an Android.
Mind you Ive turned off WiFi and BT yet Pandora takes forever to start, suddenly stop playing or huge gaps between songs.
I just dont understand how Pandora can run so good on the iPhone yet totally suck on my Droid?
I run Pandora nearly every day, for hours on end, and I have virtually no problems with it. The only time I do have problems is when I am in a poor signal area at work. It appears on par with what my iPod would do on wifi when my Evo is on wifi. My DX also had no problem with Pandora. Maybe it's your phone or the signal you're getting is weak? I just think if more people would be experiencing issues, Pandora would try to fix them. Maybe send them an email with what you're seeing?
I use Pandora to go running and my iPhone is also a Verizon phone. Run the same route everyday so I've kept the geography out of the equation.
