Pandora Widget Missing
Schwin97
Has anyone else noticed that the pandora widget isn't available any more? I have a Nexus One with 2.2 loaded on it. For the past couple of weeks it has been missing and I wanted to make sure that it was just me, or if others are also seeing this?
Thanks!
If you move the app to the SD card, the widget disappears. This is a bug and they are aware of it. If you move the app back to the phone and reboot, you can get it back.
