Hi guys
Having a unpleaant experience within 10 days of buy Samsung Galaxy Advance where battery went flat within 12 hours, had since (event was 3 months ago) been paranoid with checking the battery status & its temperature frequently. The reasons being, service center can only say that may be some buggy apps caused it without a clear solution; the only thing they did was a reset wiping out all the apps.
At the same time i read in the sticky part of this forum that Apps such as "killerApp" may be doing the wrong thing. Some guru also added that services are the real cause of high usage of battery.
In view of the foregoing, i resort to 1) "Watch Dog Lite" to monitor if i have installed any bugging app 2) turn off many services in "Setting > Application > Running Services". Is this the right path to take?
I also recently experience a phenomum where the screen refused to dim at set time limit eg 30 sec. Being paranoid, i use 3 button to reboot using the 1st option without erasing the apps.
Gurus please comment. Thank you
