I have a Samsung Galaxy Mini and I wanted to create two primary partitions on my 8 GB SD for Link2sd so that I can link the space-hogging dalvik-cache files to the SD (not into ROMs and stuff, yet
). However, when I tried to create partitions on my Ubuntu with Gparted it won't work. I don't know why, but it gives the following result:
, so I might as well find a way to partition it first and reinstall my apps later.
). However, when I tried to create partitions on my Ubuntu with Gparted it won't work. I don't know why, but it gives the following result:Also, when I mount the SD on GParted it shows that all of it is an unallocated disk (which surprised me, because I thought you need to format it even to work on the phone). The attempt deleted my appsGParted 0.6.2
Libparted 2.3
Create Primary Partition #1 (fat32, 6.78 GiB) on /dev/sdb 00:00:01 ( ERROR ) create empty partition 00:00:00 ( SUCCESS ) path: /dev/sdb1
start: 2048
end: 14221311
size: 14219264 (6.78 GiB) set partition type on /dev/sdb1 00:00:01 ( SUCCESS ) new partition type: fat32 create new fat32 file system 00:00:00 ( ERROR ) mkdosfs -F32 -v -n "Galaxy Mini" /dev/sdb1 mkdosfs 3.0.9 (31 Jan 2010)
mkdosfs: unable to open /dev/sdb1
Create Primary Partition #2 (fat32, 743.00 MiB) on /dev/sdb ========================================
