Hi folks,
What are you using as the Path variable on your terminals? Reason I ask is because I hate going to /data/busybox and doing ./ if I want to use the other commands.
But if I add a ; and add a path to the /data/busybox it seems to accept it. But then when I run su, it cames back and says no su id... I think it's trying to run the su command from the busybox vs the original perhaps?
