Help Pawnshop
qvsheen
After FACTORY RESET <<<<< on > ___new___ ROM___ was installed+facebook /through the play store. In MAIN menu where login/password require ..... was mine written《《《《login/password》》》》 .. During using ROM weren't written by me. The screen lock is=PASSWORD. The Flyme account/autosync is = OFF. The mail@××× from which facebook was downloaded > to a facebook profile is = NOT RELATED. If ... account/password are keeping in applications 《=.>& based by the phone ID.. .(result is= AUTOFILL), respectively <if selling phone to > pawnshop ∫∫∫ <it (takes passwords) , ∫ despite >>>>>>>>>> FACTORY DATA RESET?
i'm a tad confused. what do you mean by "mailbox"? are you saying after the hard reset your facebook account was still live? if so then you did not perform the hard reset correctly. just do a factory reset within your phone's settings. it will return to the phone as new and you should be fine. all of your stored passwords will be wiped clean so you do not have to worry about those.
