how do you sync songs from pc to android? ive used doubletwist wmp and songbird..but heres the problem.
when i use doubletwist, and sync, some songs get duplicated..
the bigger problem is when i erase some songs from my pc, the program does not automatically update the status/the phone does not automatically erase the songs (i was able to do this in itunes when i used iphone before)..
thanks
thanks
