Help PC Connectivity
Tihsho
So I finally dropped into the S3 world and have been regretting it over the past few hours. I've been having a hell of a time getting my pc to recognize it. When it does (only on ptp) my data connection seems to die. I cannot transfer music folders without an error that cripples everything. Plus I can't get a decent data connection on pdanet which I use for work on the road.
Any way to get the s3 to transfer files successfully through usb? If not back to Verizon it goes.
When transferring files to the sd card it says the connection must have been interrupted. If im using pdanet it just kills the data connection through usb after a couple mins.
Have you tried ditching the USB cable for music transfer? Google music or doubletwist air sync works so much better and smoother. No need to fiddle with drivers, etc.
