Help PC does nothing at all when connecting with usb
I have a galaxy s2. When plugging into PC with USB. Nothing at all happens on PC or the phone. No charging, no sounds nothing.
I have tried USB bugging on and off, set it to pda.
New USB cables, various USB Ports.
It is as if it never was connected.
I am on Android version 2.3.5
Can anyone help?
Thanks
Problem with the phones USB port? Does it charge with the wall charger?
Try cleaning the port with a toothbrush. Jiggle the port a bit. And can always send it back to have the port replaced.
Might sound like a stupid suggestion, but have you tried a different USB port.
Also, have you enabled USB Mass storage on the device?
Thanks
AP
Yes.
With our without kies, the PC doesn't even detect anything has been connected.
:dito:
I know where he is coming from, Ive already tried all ports, every other phone connects fine in the house its just Samsung phones giving me problems. Ive tried connecting with mass storage, dm mode, teethering, but none gets a response from the pc it haves to be a driver issue that i cant figure out. some1 plz help.
I'm having the same problem. My phone charges perfectly well with a wall charger but nothing happens when I plug into the laptop. tried all 4 usb ports on the laptop and nothing. it is now connecting but won't charge. That's pretty much all I want it to do when I connect it to the laptop and nothing. I've cleaned all ports etc but no joy.
Any further advice/ideas??
thanks
Other than testing with another PC and other original cables, the problem could indicate issues with the phone. In that instance, you probably would want to have it looked at under warranty.
