PC driver installation error and GoogleApps/Market with LeOS 2 beta
daniorama
Hi guys, I have a 3GW100 and I'm using it in Europe. I have used multiple firmwares from both Lenovo and the A-team, but with none of them I could install the PC drivers to access to the phone.
Right now I have the LeOS 2 beta and tried to install LePhone2.0-20101230.msi but the installation just ask me the whole time if I want to install risky drivers but it never installs them. I'm using Windows Vista (Spanish) I also have PCSuite91 installed. Anyone knows how could I install the driver?
Due to the fact that I cannot access the fastboot method I just copied the files in /system from the GoogleApps of Cyanogen but nothing changed. I tried also to delete /data/dalvik-cache/ but there is no difference. What should I do?
Thanks!
Danio, I have this drivers installed on my Portuguese Windows Vista 32 bits and working fine.
When installing I get the "not certified drivers" alert but I just click continue and it goes.
Even with the drivers installed and my phone appering as a ADB Interface device on device manager, I could not make the adb commands to work.
So I tried with the drivers installed and the 91 PC suite opened and them it worked, after that you can follow our hints on this topic:
http://androidforums.com/lenovo-lephone/254425-leos-2-0-official-announcement.html
Starting on post #19 to install the Google Aps.
Forget about fastboot, the phone doesn
Hi Pino, thanks. I see the installation of the google apps so confusing. Could you help me? This is what I've done following that thread:
1-Reinstall the Leos 2 beta (so it's new)
2-Installed z4root, root explorer and root my phone
3-Copied gapps-hdpi-20101114-signed.zip contents to my SDCard
4-Used Root Explorer to manually copy them from the SDCard to /system/ (basically the same as push)
5-? Nothing change, I don't see any new apps on the menu. What do I have to do? Install the the new apps copied in /system/app? Execute any other file? I tried installing each of the new apps and I just couldn't install one but then when I tried Market it doesn't start.
Btw, do you know if the phone works with 3G in Europe?
PS: do I need to install the whole android SDK to have adb or can I just copy the file form another computer where I have it installed?
1- OK
2 - OK
3 - Extract the gapps-hdpi-20101114-signed.zip contents to the ADB folder at your computer (I believe you can copy the ADB files only, you don
3 - ADB is part of Android SDK, I believe it's possible to download the ADB files only, but I'm not shure, if you need further informations, read this:
[HOW-TO] ADB for Dummies(How-To Learner's Guide) - xda-developers
5 - I already posted a link to another topic were we already discussed all this matters, you can find the drivers and PC suite here:
6 - Yes Wi-Fi off and mobile data on
7 - ADB is DOS only, you must use this commands on a DOS window.
Pino, it worked perfectly! Thank you! You can later install last google maps version from the apk in xda-developers.
I just copied the whole platform-tools from the SDK to make sure adb works
hello guys...
Is there someone who will be happy to make the step by step to upgrade firmware
because I'm newbi both android and member and I used lenovo lephone and by coincidence that reference very rare ...
please...write it, because in this thread and LEOS 2.0 - Official Announcement I can not understand the whole step...
