PC Interface Software for Droid 2
I cant seem to find this. Could somebody please tell me what software I can use to interface with the droid 2 using my windows 7 64 bit PC? I would like to basically just be able to see the droid menus on my computer screen and enter things. For example my WEP password is very long and it would be much easier to simply type it in my computer and have that send it to the droid 2.
Thank you, any help appreciated.
Yes, that is what I meant. Basically just connect the droid to the PC via USB and then make changes or explore using your PC keyboard and monitor instead of having to type directly into the droid with its smaller keyboard and screen. It would be easier and faster for me to do it that way
Nothing that i know of that does this. Texdro is a nice app that allows you to send your text messages from your computer like a IM chat app. I use it a lot.
