PDA Net Connecting to PC Question
  • Start date Start date
D
Deleted User
Guest
I am using PDA Net to tether my laptop. I followed the instructions to install the software, both on my Samsung Moment as well as my PC. Which is running XP 32 Bit.
After I successfully installed everything, I tried connecting but on the PC the box in the bottom right hand corner just says "Connecting to your Phone" but it will not move past that, or connect, etc.
It has been on that step for roughly 20 minutes.
Any ideas? Did I miss something?
All of the drivers were installed, etc.
But I actually just got it to work, but thanks anyway! :)
