PDANET using WI-FI from FIOS! PLEASE LOOK!!!
DDK997
I will be getting Verizon Fios Internet 25/15
My computer does not have a wireless card and I am wondering how do you turn your droid to do this?
I don't want to use my data plan to connect to the internet, I want my droid to act as a wireless card over wifi to recieve the fios from the wireless router.
Anyone know how this can be done?
(I'm currently using PDAnet using my dataplan)
Given that you are familiar with pdanet, it should be as simple as connecting your droid to wifi. Pdanet should utilize wifi by default
Wow thanks for the fast reply!
So should I first connect to WiFI, then turn on PDAnet and connect?
Are you sure it will be using the WiFI instead of my data plan?
I am also using the free version of PDANET at the moment, Will I have to purchase the full pdanet even if im using WIFI?
