Root peachsunrise help (unflash) back to stock
Hi, all
Well heres my problem.
I installed peachsunrise on my samsung exhibit ii 4g
I booted into recovery (cwm)
Selected ROMswipe
Chose install zip from sdcard
chose zip from from sd card
chose peach.sunrise zip file
it worked then rebooted and wallah i was running peach sunrise.
After using it for a while i got board and wanted to go back to stock by
using the sgh-t679 zip
opened odin v4.43.exe (which i used before to restore my phone back to stock after i rooted it before but did not try peachsunrise) and it worked.
This time around (running peachsunrise) i tried the same method and it failed to work.
Everything force closed on me.
So i once again followed the steps to run peachsunrise as listed below and im running peachsunrise again.
I want to retore mybphone back to stock and zergrush it again.
How do i do this?
Once again any feedback would be great and much appreciated
thanks
crzylibra77
PS I liked peachsunrise it was the only custom rom i ever tried im just having issues with it and cant tether my phone to my laptop and use my exhibit ii 4g as a hotspot to go on line with my laptop. That is not the only issue i enjoyed rooting and self customization.
I backed up using titanium backup. Can anyone please tell me where i would find the back up using my ES File Explorer. I just want to locate it so i make sure im restoring it to the back up i created. I understand that if this doesnt work I am the only one to blame. But i will for sure go on here to find a solution if i do mess it up, lol.
Thanks again, hope to hear from someone soon
