Peggle on Transformer Prime
drdav
When I try to buy Peggle for my Transformer Prime, it says that it is not compatible. Is there a way to get around this on a stock (Non-rooted) system?
If you can get the .apk somewhere then upload it and install (you will need to check the "install from unknown source" setting).
Ask someone who is rooted to pull the apk for you. I don't have it.
