Perform as a USB memory stick on a computer?
bhavbhuti
Hi all
I presently use WM5Storage with my HTC Touch Windows Mobile to convert the phone into a USB stick to transfer files to a computer that is not mine.
Is this possible in Android?
Thanks and regards
Bhavbhuti
no need for an app...
just plug it in... easy as falling
check out my signature... about dropbox...
it will help you sync files .. across many devices/PC
very very useful and free
Thanks Dan. I do use DropBox for the PC, but thanks for pointing out the Androod version is there too, will keep it in mind. Can DropBox do this over a USB or BlueTooth between the PC and the Android phone or it has to use internet connection only?
Please advise
Kind regards
Bhavbhuti
it is over the internet..
via... wifi.. or cell mobile data...
what ever it sees (in order: wifi, then mobile)
what ever dropbox you add/change/delete files in that device..
from there it syncs up to the dropbox website (the cloud)...
then syncs down to all the accessed dropbox in all your devices.
