Hi guys. I've googled this a lot and browsed a lot of forums and I can't seem to find a through explanation on the pro's/con's with having either a deodexed or odexed firmware.
I know that odex files are optimized dex files outside of the apk and that having it like this saves a bit of space in the dalvik cache folder and that the system boots faster after each consecutive dalvik wipe.
This, however, makes it impossible or next to impossible to modify the files.
I know that deodexed makes for some very easy modding, but that a deodexed rom has less available space (because dalvik takes up more) and that the apk's are no longer optimized because the odex files have been converted to normal dex files and compiled into the apk. This makes the system boot slower after each consecutive dalvik wipe as it has to rebuild the dalvik completely and that the system needs longer time to "settle" because of the caching.
Over than that, is there any performance difference whatsoever between them? I've looked for this everywhere but haven't been able to find a logical answer. Some people say apps generally open faster and are much smoother, but is this actually true? Is it worth the time deodexing and reodexing every time you want to mod something?
I don't think so. I like having a completely deodexed system /app+framework) just so that I can flash a mod easily whenever I please.
Cheers.
Cheers.
