Personal ringtone
DrRichard
Is it possible to use a personal ringtone on the Mini, I have got the Galaxy S and my wife wants personal ringtones on her new Mini
Help please
In 'Music' the song that's opened with the player can be set.
While in the player, click the menu button, there is a 'Set as ringtone' option.
1. Create 3 folders in the SD card and name them as 'alarms','notifications' and 'ringtones'
2. Put the desired music files into these folders
alarms - sounds which you like to set as alarm tones
notifications - sounds which you like to set as text message tone & for other notifications
ringtones - sounds which you like to set as ringtones for incoming calls
3. Then goto settings->sound and check the ringtones list. You will see that music files in it
4. Try to change alarm tones in menu->clocks
