pettern unlock
  • Start date Start date
A
Android Question
Guest
i forget my pettern lock & now my mobile phone need to be my gmail or security question but i heve not any one. noe at this time how do i do. piease help me my mobile is exreria x10 mini pro.
Do you not use the Play Store? It means that Google account - the one you entered when you first set the phone up. Doesn't matter if you don't actually use the GMail associated with it, but it's that account.
Now if you've forgotten what the account is you probably don't have any option but a factory reset, which will wipe all apps and data. This is a security feature: if there was a trick to just bypass a pattern lock, what would stop a thief using it? Of course if you don't know your google account you won't know how to set up the same Play Store account after a reset, so it would be better to try to remember the account. Check whether you got a "welcome" message on your regular email account when you set it up.
We do have some more information available here: http://androidforums.com/faqs/685025-lost-phone-locked-out-faq.html
Good luck!
